Wheel alignment
11-24-2004, 08:46 PM
Wheel alignment
I took my car to Julian at WMS in Watford.
I wanted the settings looking at on my AE86 and see what needs to be changed.
So Wayne, the alignment expert fitted all the laser equipment to the car and we got the settings.
Left Right
Camber -3.74 - 3.05
Caster 2.20 2.15
Toe 0.45 0.28
So after speak to Paz about suggested setups and then discussed different options with Julian.
Luckily my car has camber top mounts and adjstable tension rods.
So we settled on a compromise for me to learn with and then when I get better we can make the settings more extreme if I need
Left Right
Camber -3.00 -3.00
Caster 3.50 3.50
Toe 0.05 0.05
Happy with it so far, I wanted more castor but we got the end of normal adjustment, and any more forwards would foul the front bumper on turning.
Sunday will tell !
So i cant recommend enough the service at WMS. So if anyone wants there alignment sorting out, call them on 01923 210662. Ask for Julian Smith.
If you dont know who Julian is, he drives the E30 BMW with graphics all over at the D1 and practice days and is one of the best drifters in the country.
Cheers
Si
11-24-2004, 09:09 PM
Wheel alignment
Did you sit in the car when you aligned it?
11-24-2004, 09:15 PM
Wheel alignment
No i didnt, and i know that affects the camber settings.
However, I'm gonna test it as is, atthe drift day this sunday and then get it tweaked if need be.
11-24-2004, 11:39 PM
Wheel alignment
Simon Goes Sideways Wrote:No i didnt, and i know that affects the camber settings.
I am running almost the same settings but with -3.5 deg of camber. Grip during cornering in the front is very very good Big Grin Big Grin
11-24-2004, 11:42 PM
Wheel alignment
Simon Goes Sideways Wrote:Imore extreme if I need
Left Right
Camber -3.00 -3.00
Caster 3.50 3.50
Toe 0.05 0.05
That's the setting i was driving these summer season until i hit the fence. Confused
It was a great improvement from stock. Much more grip while drifting.
I have camber plates, but tie rods are stock. No need for aftermarket tie rods because these are adjustables OEM.
I'm runing bit more toe out for better turn in.
Did you realign you rear suspension with adjustable panhard rod, if you have one?
11-25-2004, 01:51 AM
Wheel alignment
Already have adj panhard and its aligned just right
  alignment issues after re-install of coilovers NBU 21 19,833 08-03-2013 06:18 AM
Last Post: allencr
  Street wheel alignment. Aram 11 12,628 03-31-2013 04:24 PM
Last Post: Aram
  How to improove oem WHEEL ALIGNMENT settings (toe&caster Apolan 13 13,480 03-12-2008 02:58 PM
Last Post: Roku_trueno
  Front alignment totta Crolla 3 4,174 12-11-2006 11:27 PM
Last Post: totta Crolla
