gze oil
07-04-2011, 12:45 PM
gze oil
Hello all
i've just replaced all the bottom end bearings on the gze.
what oil do you recommend putting in and how many miles shall i use it for before changing it.
The world without TOYOTAs, cant imagine it.
07-04-2011, 04:13 PM
gze oil
Running in new bearings doesn´t require any special oil or a special procedure. Just use any 10W-40 and change after 250/300km and you should be fine. Smile
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
07-04-2011, 08:38 PM
gze oil
Bearings don't need running in at all (if they wear down, you can throw them away). You could do an oil change to check for particles and such, but really it shouldn't make any difference. Run-in is only required for new piston rings.
07-05-2011, 12:11 PM
gze oil
thanks guys
07-05-2011, 01:09 PM
gze oil
Ivan141 Wrote:Run-in is only required for new piston rings.
And cams...
  trans oil, lsd oil change Apolan 9 17,609 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 31,835 06-06-2013 07:36 PM
Last Post: Deuce Cam
  DLI GZE no spark 4agetercel 5 7,355 02-01-2013 07:05 PM
Last Post: 4agetercel
  GZE Swop with PAS & AC Lauren 12 14,459 02-16-2012 01:04 PM
Last Post: heshan
  Engine sounds slush GZE with VIDEO ! Okami 13 15,329 01-03-2012 12:12 PM
Last Post: Okami
