oil pan
08-21-2010, 08:22 PM
oil pan
I would like to remove my oil-pan from my ae86.
I already removed the bolts and nuts, but i can't take the oil pan away because the oil pick-up blocks it.
can i remove the oil pan without de-mounth the engine?
http://bruutt.blogspot.nl/
08-21-2010, 08:59 PM
oil pan
i already fixed it,
i had to removie te plate from the oil-pan.
when i removed that plate i had a lot more space to move the pan, and i was able to remove it.
This topic can be locked! Thumbs up!
  Oil Pan Issue Alex170984 6 7,148 01-11-2016 04:50 PM
Last Post: Alex170984
  trans oil, lsd oil change Apolan 9 17,599 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 31,797 06-06-2013 07:36 PM
Last Post: Deuce Cam
  Oil Pan connection Alex170984 3 4,599 05-01-2013 12:01 PM
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 8,114 10-01-2011 09:47 AM
Last Post: demogun
