what 4.7 final ratio??
05-16-2011, 09:33 PM
Hi mates, i'm thinking to buy a 4.7 final ratio from tokyoseven
Any body has one since a lot of Kms?
Is it durable or spits teeths?
Noisy? (no for a track car)
I know acceleration will be better, but it feels?
I calculated at 3.000RPM in 5th will go to 100 Km/h (on tacho), it is truth?
Other durable marks are better? (like Weir Performance, etc)
Thanks, all oPINIONs are welcome :wink:
[Image: AEU86 AE86 - what 4.7 final ratio??]
05-16-2011, 09:39 PM
The 4.77 final drives are a great addition to our cars. especially if you are running a LSD with a somewhat stock motor. It gives you much more usable power in the mid to high rpm's.
The Good
*Great acceleration
*Great Braking
*New unit, has not been abused yet.
*Is a stronger unit since it has newer materials and forging techniques.
* NOT 25 years old.
The Bad
* Will make a slight noise (This may differ on the installer, but it will give a very little whine as there is more pressure on the gears.) If you have full interior and installed and shimmed properly you will barely hear it.
*If not installed properly will be very loud and break gears.
K1 Motorworks
14840 Valley Blvd, Unit K
City of Industry, CA 91746
[email protected]
05-16-2011, 10:19 PM
I like 4.7 on my stock 4a-ge.
Car feels like it has more torque.
I would recommend it.
05-16-2011, 10:26 PM
your tacho still points the same speed / rpm because the signal comes out of the transmission and not out the diff..
but when driving 120 @ 4k on your tacho its about 100/105 on gps..
'87 levin coupé
05-16-2011, 11:25 PM
Hola tomas se de otro sitio mas barato que tokyoseven
05-17-2011, 12:18 AM
Thanks everyone!
Then it is quite noticeable, ZaX mine is stock too (except two exhaust cams)
Yversion, i didn't thought about newer materials and forging techniques, that's OK
PatrickAE86 Wrote:your tacho still points the same speed / rpm because the signal comes out of the transmission and not out the diff..
I thouhgt the signal came from a wheel Huh i think my 86 is my bike
trdtwincam16 hola Echedey, pues "escupe", jeje , son los mismos o de otro fabricante? (Hi, let's tell me, are the same or from other manufacturer?)
  Final drive calculation. Aram 31 40,529 12-24-2014 03:08 PM
Last Post: Uzelac
  Ring & pinion ratio. izanagi 27 34,838 07-05-2014 07:35 PM
Last Post: assassin10000
  5.375 final drive ratio with stock T50 4000GT 23 32,752 08-07-2012 01:08 PM
Last Post: 4000GT
  changing diff ratio, broken LSD??? fax0815 6 9,581 09-06-2011 08:19 PM
Last Post: fax0815
  Final Drive ratio - need advise KD2229 12 19,869 08-26-2011 08:33 AM
Last Post: totta Crolla
