what 4.7 final ratio??
05-16-2011, 09:33 PM
Hi mates, i'm thinking to buy a 4.7 final ratio from tokyoseven
Any body has one since a lot of Kms? Is it durable or spits teeths? Noisy? (no for a track car) I know acceleration will be better, but it feels? I calculated at 3.000RPM in 5th will go to 100 Km/h (on tacho), it is truth? Other durable marks are better? (like Weir Performance, etc) Thanks, all oPINIONs are welcome :wink: |
05-16-2011, 09:39 PM
The 4.77 final drives are a great addition to our cars. especially if you are running a LSD with a somewhat stock motor. It gives you much more usable power in the mid to high rpm's.
The Good *Great acceleration *Great Braking *New unit, has not been abused yet. *Is a stronger unit since it has newer materials and forging techniques. * NOT 25 years old. The Bad * Will make a slight noise (This may differ on the installer, but it will give a very little whine as there is more pressure on the gears.) If you have full interior and installed and shimmed properly you will barely hear it. *If not installed properly will be very loud and break gears. K1 Motorworks 14840 Valley Blvd, Unit K City of Industry, CA 91746 [email protected] |
05-16-2011, 10:19 PM
I like 4.7 on my stock 4a-ge.
Car feels like it has more torque. I would recommend it. Drifting - best fun you can have in your car with your pants on! |
05-16-2011, 10:26 PM
your tacho still points the same speed / rpm because the signal comes out of the transmission and not out the diff..
but when driving 120 @ 4k on your tacho its about 100/105 on gps.. '87 levin coupé |
05-16-2011, 11:25 PM
Hola tomas se de otro sitio mas barato que tokyoseven
05-17-2011, 12:18 AM
Thanks everyone!
Then it is quite noticeable, ZaX mine is stock too (except two exhaust cams) Yversion, i didn't thought about newer materials and forging techniques, that's OK PatrickAE86 Wrote:your tacho still points the same speed / rpm because the signal comes out of the transmission and not out the diff.. I thouhgt the signal came from a wheel i think my 86 is my bike trdtwincam16 hola Echedey, pues "escupe", jeje , son los mismos o de otro fabricante? (Hi, let's tell me, are the same or from other manufacturer?) |
Final drive calculation. | Aram | 31 | 32,215 |
12-24-2014 03:08 PM Last Post: Uzelac |
Ring & pinion ratio. | izanagi | 27 | 27,596 |
07-05-2014 07:35 PM Last Post: assassin10000 |
5.375 final drive ratio with stock T50 | 4000GT | 23 | 26,362 |
08-07-2012 01:08 PM Last Post: 4000GT |
changing diff ratio, broken LSD??? | fax0815 | 6 | 7,726 |
09-06-2011 08:19 PM Last Post: fax0815 |
Final Drive ratio - need advise | KD2229 | 12 | 16,214 |
08-26-2011 08:33 AM Last Post: totta Crolla |
