OIL:)
08-11-2008, 03:34 PM
Post: #81
OIL:)
Sort of summary of oils preferably used by AE86 owners dissected into sections. I did not put down every kind of brand named here, mainly the ones with some more specifics to it (grades and stuff)
Engine oils - typical 10W40 semi synth oils Fresh refill tends to need approx 4L (3.8L) Branded: Castrol RS 10W60 full synth Castrol GTW 10W40 Valvoline Durablend 10W40 Valvoline Maxlife 10W40 Gastrol GTX 10W40 Motul 300V LE MANS fully sync 20w60 Tranny oils - typical 75W90 GL4 Fresh refill needs about 1.3L Branded: Redline MT90 (GL4 75W90) Diff oils (LSD) Depends a bit on application, for branded LSD's use brand diff oil. KAAZ LSD: KAAZ LSD GL5 oil TRD LSD: TRD LSD oil (FR) CUSCO: Redline diff oils Fresh refill tends to need 1.3L Branded: Castrol 75W140 GL-5 Valvoline Durablend GL-5 LS Motul 90PA LSD MPM SAE-90W GL-g Castrol Saf-Xo Let me know if there's more, whether there is a general consensus of what's good and what's not good (i.e. something like a "We from AEU86.org recommend ....." ) |
08-11-2008, 10:03 PM
Post: #82
OIL:)
AE86 GTS '84 Red Top |
09-15-2008, 12:57 PM
Post: #83
OIL:)
http://www.carbibles.com/engineoil_bible.html
interesting read about engine oils, and even a nice tutorial on engine oil change. ![]() |
10-09-2008, 10:18 PM
Post: #84
OIL:)
))) aand what is GL4, GL5 marking?
ehat i need give to eat my t50? Rising Sun T |
09-10-2010, 05:54 PM
Post: #85
OIL:)
agip racing 10w60 on my 400000km ae86
09-24-2010, 12:35 PM
Post: #86
OIL:)
350k km on mine. The last 140k km I was using full synthetic oils like: Castrol RS 10w60, Fuchs titan 5w-50 and Liqui Moli Racetech 10w60. After winter, I will try to put Motul 6100 15w-50, in order to reduce oil consumption (1 liter per 5000kn with 10w-60).
Gulf gearoil LS for LSD – cheap & good ![]() Fun is not the straight line! |
09-24-2010, 12:53 PM
Post: #87
OIL:)
I use 10W60 (less oilcomnsumption compared to 5W40 I used before)
Brands: Silkolene, Castrol EDGE or TWS what ever I can get my hands on ![]() Oil pressure on the stock gauge never goes below middle even after a couple of hot laps with temps reaching 100°C AE86 ex-daily |
09-25-2010, 08:41 PM
Post: #88
OIL:)
Mux213 Wrote:No technical forum is complete without the everlasting fighting between members over their choice of oils. dayli use 3AU engine 860kg aprox dayli km : 45km to 70km argentinian elaion no problema hahaha ![]() ![]() ![]() |
09-25-2010, 09:21 PM
Post: #89
OIL:)
Use: predominantly track days (back in the day)
Brand: ALDI, LIDL or whatever convenience store has something on offer Problems: none.. [NoHachi, who believes that changing oil every couple of months is better insurance then spending money on expensive brand marketing.] A wheel to steer the front of the car A pedal to steer the rear |
12-07-2010, 04:58 PM
Post: #90
OIL:)
waking up the old tread...
i know GL-5 shouldnt go in gearbox but i have some Motul oil 75W90 that fills up GL-4 and GL-5 specs. is that safe for our boxes? |
trans oil, lsd oil change | Apolan | 9 | 17,475 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 31,453 |
06-06-2013 07:36 PM Last Post: Deuce Cam |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,995 |
10-01-2011 09:47 AM Last Post: demogun |
Oil Presure and what oil i have to use? | CHACAMAN | 4 | 5,605 |
08-27-2008 05:35 AM Last Post: F0Bman |
High engine oil temps - oil cooler discussion | SutteR | 28 | 24,122 |
06-08-2008 11:23 PM Last Post: eight-six |
