OIL:)
01-04-2006, 09:34 PM
Post: #71
OIL:)
I said also that for the rear end is much better to use GL-5 instead of GL-4 oil. Gears are different stuff (T50 uses brass parts sp recommendation is GL-4 , not GL-5).
01-04-2006, 11:05 PM
Post: #72
OIL:)
ok Jammie! i will use Shell Spirax (75-90 if i remember well..) GL4 for tranny and ELF gear oil for LSDs.
AE86 FANATIC!!! |
08-30-2006, 11:12 AM
Post: #73
OIL:)
Anyone know the best oil to use in a 2 Way diff or would it be the same as the standard LSD?
08-30-2006, 05:32 PM
Post: #74
OIL:)
I'm using Valvoline SynPro 5W-40 changing every 5000 km... low mileage engine... runs perfectly fine... still need to buy and fit oilfilterrelocation kit and some proper senders&gauges
![]() AE86 ex-daily |
08-30-2006, 05:43 PM
Post: #75
OIL:)
I wouldnt mind an oil filter rellocation kit either. One of the disadvantages of keeping the air con, the pulley gets in the way
08-30-2006, 07:03 PM
Post: #76
OIL:)
for the engine i use denicol Viscolube racing sae 40w50
before the oil pressure was in the midle of the 2 stripes and now with the denicol it is on the max. and for the gearbox and rear axl i use denicol sae 80w90 limet slip |
06-27-2008, 11:10 AM
Post: #77
OIL:)
Guys i have a question should i use synthetic oil or mineral oil for LSD differential or transmission ? thanks for the answers :wink:
85' AE86 GT coupe lifetime project since 2005 |
06-27-2008, 08:27 PM
Post: #78
OIL:)
I'd say get synthetic if the diff/gearbox you're putting it in is in good shape..
06-28-2008, 08:28 PM
Post: #79
OIL:)
NEO 10w40 for engine and always Redline transmission fluid
06-28-2008, 11:02 PM
Post: #80
OIL:)
I used 20-50 for older motors and 10-30 for fresh motors.
trans oil, lsd oil change | Apolan | 9 | 17,309 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 31,063 |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,910 |
Oil Presure and what oil i have to use? | CHACAMAN | 4 | 5,537 |
08-27-2008 05:35 AM Last Post: F0Bman |
High engine oil temps - oil cooler discussion | SutteR | 28 | 23,803 |
06-08-2008 11:23 PM Last Post: eight-six |
