OIL:)
01-04-2006, 09:34 PM
Post: #71
OIL:)
I said also that for the rear end is much better to use GL-5 instead of GL-4 oil. Gears are different stuff (T50 uses brass parts sp recommendation is GL-4 , not GL-5).
01-04-2006, 11:05 PM
Post: #72
OIL:)
ok Jammie! i will use Shell Spirax (75-90 if i remember well..) GL4 for tranny and ELF gear oil for LSDs.
08-30-2006, 11:12 AM
Post: #73
OIL:)
Anyone know the best oil to use in a 2 Way diff or would it be the same as the standard LSD?
08-30-2006, 05:32 PM
Post: #74
OIL:)
I'm using Valvoline SynPro 5W-40 changing every 5000 km... low mileage engine... runs perfectly fine... still need to buy and fit oilfilterrelocation kit and some proper senders&gauges Smile
AE86 ex-daily
08-30-2006, 05:43 PM
Post: #75
OIL:)
I wouldnt mind an oil filter rellocation kit either. One of the disadvantages of keeping the air con, the pulley gets in the way Crying
08-30-2006, 07:03 PM
Post: #76
OIL:)
for the engine i use denicol Viscolube racing sae 40w50
before the oil pressure was in the midle of the 2 stripes and now with the denicol it is on the max.
and for the gearbox and rear axl i use denicol sae 80w90 limet slip
06-27-2008, 11:10 AM
Post: #77
OIL:)
Guys i have a question should i use synthetic oil or mineral oil for LSD differential or transmission ? thanks for the answers :wink:
85' AE86 GT coupe lifetime project since 2005
06-27-2008, 08:27 PM
Post: #78
OIL:)
I'd say get synthetic if the diff/gearbox you're putting it in is in good shape..
06-28-2008, 08:28 PM
Post: #79
OIL:)
NEO 10w40 for engine and always Redline transmission fluid Thumbs up! Best setup for any highly tuned engine.
06-28-2008, 11:02 PM
Post: #80
OIL:)
I used 20-50 for older motors and 10-30 for fresh motors.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  trans oil, lsd oil change Apolan 9 17,309 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 31,063 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 7,910 10-01-2011 09:47 AM
Last Post: demogun
  Oil Presure and what oil i have to use? CHACAMAN 4 5,537 08-27-2008 05:35 AM
Last Post: F0Bman
  High engine oil temps - oil cooler discussion SutteR 28 23,803 06-08-2008 11:23 PM
Last Post: eight-six
